Plugs & Coils-do you change them in a certain interval?
https://www.ford-trucks.com/forums/1...-pictures.html
5.4L are a little bit different, sometimes issues removing plugs, the 6.8L 2-valves had more of stripping loose plug issue. Different torque I believe as well, so yes definitely find one for your engine.
Not quite, the issues are identical Sammie. You are confusing the '05+ 3V heads with the two-piece plug design. To my knowledge the problems removing plugs affect both V8 and V10 engines with 3V heads. Likewise the problem with spitting plugs affects all 2V modulars up until 2002 or 2003, including 4.6L, 5.4L, and our 6.8L V10s.
2v or 3 v issue not a 5.4 or 6.8 issue I guess, all I really know is my engine so definitely find out about your own before you attempt to change the plugs. Mines a 2v 6.8 and I had no real issues getting my plugs out. Did have one blow years ago on another 2v I owned.
Here is the deal on repairing the spitting plugs issue. I have had to repair several (well over 25) stripped spark plug holes in 4.6 and 5.4 engines that my extended family bought between 98 and 2003. Before Ford even officially acknowledged that there was a problem, the Time-sert company had a elegant solution. I bought their kit when the issue first arose within the family fleet, and it worked like a charm. Not a single incidence of failure or problems in any of the spark plug holes years after the repair.
The kit is not cheap, but is a lot cheaper than a dealer or mechanic doing the repair. You must be meticulous withthe process, an that means take your time and get everything right. Use lots of grease on the reamer and tap and clean it very often and put on fresh grease. The grease captures the chips and keepst them from falling into the cylinder.
The Time-Sert kit is now the "Official" repair for the heads from Ford. Good thing, too, as it makes a permanent proper repair. I will tell you that whether you have a early or late aluminum head, if you put the inserts in, The repair is stronger and better than the head originally was.
