Triple disc of single disc TC?
I talked with a reputable tranny builder here about a tranny build that I will be getting done at the first of the year and he says a good single disc with a billet cover would suit my needs. I tow a 9k TT 3-4 times a year. I thought about going with triple disc anyway but he says it will not shift like stock. Can't the line pressure be adjusted so it will not shift so hard? I am thinking that most here that did a rebuild have a trip disc . How does it compare to stock? Thanks
After getting my JW trans, it shifted just slightly harder than stock, not a death bang into gear or anything... Jody tuned it down just a little for me and now it's as smooth as butter. I would recommend going with JW or BTS if you can afford it (not sure what the local builder has quoted). John uses suncoast TC's now and I think BTS uses precision TC's (not sure). Anyway, get your hands on either one of these trans and never look back!
WOW!!! You can buy a precision for around 1350.00 which is one of the best out there for the 4R100.
on
300M Input Shaft, Cryoed Center Shaft and Input Shell, Chrome Moly OD Planet Housing, Increased Count Clutches on all Packs, Billet Forward Drum, TransGo & Sonnax Pump and Valve Body Mods, Sonnax Bypass Tube Rebuild, 6.0 Trans Cooler, and External Trans Filter. Some of these upgrades were part of a previous rebuild and others were added recently due to torque converter/input shaft failure at RRE this year.
Here is a bracket, I built, to attach the trans to my engine stand.
Attachment 66111
Attachment 66111
Since a average rebuilder could use the same parts but if he doesn't take the time to set clearances correctly it is all in vane.
By the way that is one clean trans case!! Did you paint it too?/
