Gasoline fuel filter R&R
Probably everyone has done this already, it's an easy afternoon job. Can't even finish a beer.
Disconnect neg terminal on the battery, relieve fuel pressure on the system, have an absorbant towel handy to catch the fuel that spills, buy a plastic fuel filter tool, get ready to wrangle the line loose, some PB blaster may help. Once the line is loose, point it upward so the gas doesn't continue dripping.
The following users liked this post:
I know we all seem to replace this part every now and then , but is the fuel carrying so much crud it makes a difference?
I changed mine last year again , and i dont think there was any noticable difference.
has anyone taken the filter apart to see whats being caught up inside?
I may get flamed here. Answer to your question is no. Fuel filters don't get plugged up unless there is a problem. The ONLY times I have seen plugged filters are when the gas tank is rusted, a rubber fuel line degraded, or some other failure. Without any other issues like the rust or rubber breaking down you should never HAVE to change a fuel filter. I have cut open filters many times before just to see whats plugged in the filter. I have cut open only a couple still good filters which looked like new inside even after a couple hundred thousand miles. I have quit changing fuel filters honestly (besides the diesels) and have yet to have a problem with anything around here because of an old filter, trucks, cars, lawn mowers, you name it.
Diesels on the other hand do get junk in the tanks from some stations and should be changed every so often.
Condensation in the tank will cause a filter to clog due to the element becoming saturated and swelling.
The things are cheap and easy enough to replace every year.
It may be a waste to do it that often, but I do for peace of mind. Sort of like the windshield wiper that still has some life in it, but gets replaced anyway.
Last winter my shop got a new account because of stopped up fuel filters . The company has a fleet of crown vics with returnless fuel systems . A few of the filters were so full of water they froze solid ! Change them on a regular basis and by name brand fuel . Another tip , do not buy fuel while the tanks are being filled . All the trash and water gets stirred up and can temporarily be suspended and make it to your tank ! I once had a car towed in from a pump with 8 Gallons of water in the tank !
Wear glasses, and old clothes. You're going to smell like fuel.
