2008 F550 wrench light
hard to say without the codes but the wrench light indicates a powertrain fault.
If you motor sped up then check all your fluids. It maybe that it prevented a runaway.
A runaway could occur perhaps from overfueling. High engine oil levels.
Not that this is your case. Just an idea. Can you read the codes? Check all your fluids.
if you had a massive amount of water it may not come on.
If you are are pretty good at changing your own fuel filters then I would advise pulling the engine fuel filter and shinning a light into the fuel bowl See if you have metal or rust forming.
If so then you are in need of a fuel system flush and new hpfp.
So you see this could be serious or maybe not till you check futher.
robr0924
20
04-20-2006 06:54 PM
