On the piece I would call the lower front apron (the piece the bumper brackets go through and the lower end of the teeth bolt to) has 5 small holes in a line about under the radiator. What bolts into these 5 holes?
Thanks,
Tractorman Bill
Might be better if I waited and bolted everything together and then built a lower radiator plate to fit the radiator/condenser, etc. that I put on the unit or do you think a stock plate would fit?
Tractorman Bill
