Explorer whine in rear
Well i picked up a 96 4x4 with the 4.0 a few weeks ago and been fixin stuff weekly that i find wrong. One thing i noticed was the rear diff was leaky but couldnt get the fill plug out so left if for now. Last night my wife was on interstate and it just started making a loud noise so she pulls over calls me. I get there and drive it and it makes a woowoowoo noise and it got louder as speed inscreased. She was 3 miles from the exit so i drove it about 15-20 to get it off interstate than another 2 miles to her sisters. We let it sit for a few hours and found a flatbed to haul it home, and when we finally got home i drove it off the flat bed and now it was making a loud clunky noise. Parked it in drive till today. Cracked open the rear and no fluid came out. Inspecting all the gears looked good no metal in bottom so i went and got a new rear cover and 3 qt. of fluid. Put it back together and the woowoowoo was still there but seemed to slowly go away as i drove it around the block. So what else could be going on here or do i need to drive it and warm up the fluid so it circulates? I also noticed a sheeee sound like metal on metal when brakeing but i changed all 4 rotors and both pads last week but i noticed the brakes in the rear that look like drum brakes was bare but i assume that is only for the ebrake so didnt bother changeing them yet. Could those be hitting the inside of the rotor and makeing the metal to metal noise?
squeel like suck?
V1329 06 12 12 - YouTube
I only have this at low speed (think max of 15) though and mainly under torque, once in a while I have it at coast, with or without brake on. I was told it was the universal although there is min. to no play in it. Gonna tackle this problem in about 2 weeks when I have a helper and other work is gonna be done at same time. Sry but gotta tilt head to left to see it at the right angle.
http://youtu.be/TISMLqceAUg
I just made this vid so you can hear the noise and my speed didnt go over 45.
YEs, i was going to say the pumpkin is deeper than the alxe tubes and when our run down to the last few ounces, i would think the ring gear would throw oil on the carrier and pinion bearings, while the alxe bearings by the brakes would be dry. I think the axle bearings would be first to go, then the pinion. I would change out both axle bearings if you have the cover off and housing drained.. your half way there at that point.
I just filled the rear if i drain it in a clean can could i reuse it or trash the fluid and get new again? Plus i looked at my tag on my cover and it said 3L73 which is limited slip correct? But when i turn one wheel the other spins the other way, i thought limited slip was both would spin the same direction?
