Oil Pump Driveshaft - which end goes in pump?
Okay, I took 361 photos of the engine when tearing it down and didn't take one that shows the oil pump driveshaft and the oil pump. There is a ring on one end and I'm assuming that the end with the ring goes into the pump. But then I thought, "hmmm, wouldn't that prevent the shaft from be driven into the pump to, uh, you know, actually pump?"
So if anyone knows then I'd appreciate the help.
Like stated, the ring goes towards the top of the engine, and is there to keep you from pulling the shaft out of the pump upon removal of the distributor.
If you're going to use a high capacity/volume pump, I'd really advise that you use an ARP oil pump drive. I questioned my machinist about it and he just sat down and ordered me the shaft... Hardly gave me the option to use the stock shaft. They tend to twist up like licorice with the increased drag that you'll see with a higher capacity pump. I used the Melling HV on my mill. Cleared my truck pan no issues. 95' 5.8L.
F150Conno
04-25-2004 11:10 PM
