79 F150 FRONT ROTOR REMOVAL
I need help with removing the drivers side front rotor. I've removed tire, 4x4 hub cap, removed what I would describe as a retainer ring that allowed a piece (not sure exactly what) to come out that was holding in a spring. Now I'm stuck, I don't see anything else thats holding the rest in and can't seem to get to the Lock nut. I have a lock nut socket (rented from Advance). Any help would be much appreciated. P.S. Not to sure how to upload pictures. I have one that illustrates where I'm at.
Here's a diagram:
Thanks for the info... is and will be very helpful. I've gotten the first lock nut, spacer or washer and the second lock nut off. From what I've read the rest of the hub assembly and rotor should come off now?? It has a slight bit of movement now that the lock bolts are off but its not comming off. What's next?
There are two retainer clips... The one that goes around the axle shaft and the other which fits into a groove on the inside of the hub about 3/8 of an inch or so in... These can be covered in grease which hides them. They are either round or square rings. Silvers suggestion about the hook is good but a sharp finishing nail can do the trick as well. You will have to find the gap between the ends on the ring to fish it out.
Do you have both rings out?
cpinter10
44
01-13-2011 06:17 PM
mkdubs
11-13-2009 04:26 AM
lydell
09-06-2003 06:31 PM
