SGII new Xgauge testing volunteers?
Here are a few more Xgauges to try.
Let me know how these work for you. I'm going to try the Glow plug coil time tonight.
These have been requested by a few members from different forums, and James at Linear Logic has been nice to provide these.
From James. ( By the way, He just recently got Married!!! Congrats James!)
"Here’s what I’ve come up with for the XGauges requested.
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
Note: This one seems a bit odd, but try it out and let me know if you need finer resolution. This one will go by whole numbers, but the range is something like +/- 32 Volts which seems weird for a sensor – they’re usually 0-5 volts
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
Note: This one may have weird readings if the values get to high, let me know.
Glow Plug Coil Time (Seconds)
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
Glow Plug Lamp On Time (Seconds)
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
Try those out and let me know how they do."
Regards,
James DeLong
Linear Logic LLC
Operations Manager
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
Regards,
James DeLong
Linear Logic LLC
Operations Manager
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
Regards,
James DeLong
Linear Logic LLC
Operations Manager
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
Regards,
James DeLong
Linear Logic LLC
Operations Manager
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
Sean
As for the light, I don't really see how that would work for diagnostics. Although, you would be able to notice just how much longer it stays on at which temps and if the truck has been plugged in.
Maybe, and this is just a thought. Maybe the light would stay on longer with a weak plug. But, a person would have to learn just at what temp the light stays on and for how long, then notice it staying on longer at the same temp.
Mine sits at 62, then when they shut off it goes to zero. ( I can tell by watching the volts go up when they shut off)
Sent James a note, and hopefully he will have an answer.
I was also hoping for this one. The other 2 really don't matter I don't think.
Here's a couple more for you:
Crank and Cam sync
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3701
MTH: 000100010000
NAM: CCS
FICM Sync
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3601
MTH: 000100010000
NAM: FIS
The first is the Crank and Cam sensors signals are in Sync with the PCM. The second is the FICM indicating that its values for the CKP and CMP sensors are in sync with the PCM readings.
Crank and Cam sync
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3701
MTH: 000100010000
NAM: CCS
FICM Sync
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3601
MTH: 000100010000
NAM: FIS
