Grinding metal sound while turning key
Old 12-03-2012, 11:25 AM
Michelle Pip's Avatar
Michelle Pip
Michelle Pip is offline
I got a 98 f150 with a 2 year old starter in it. When I go to start the truck I turn the key and it makes a horrible metal crunching sound. If I quick stop, then turn it again, it'll start.
I saw another thread here with 'occasional grinding noise' but this just started, and happens every time I turn the key.
Does anyone think it is time for a new starter or should I look towards the fly wheel or something else???
Old 12-03-2012, 12:05 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
The bendix spring on the starter has/is failing...is essentially throws the starter gear into the flywheel/flexplate to spin the engine...if its been grinding for a while, you will need to check the ring gear on the flywheel/flex plat to make sure it is not damaged...if it is, pull it and the ring gear can be replaced
Old 12-03-2012, 12:21 PM
Michelle Pip
Thanks. I haven't used my truck since I heard that noise on start, so it only rattled maybe 3 times, so hopefully no furthur damage was done.
Sounds like the easiest thing for me to do is replace starter (again).
rled
6.7L Power Stroke Diesel
04-16-2021 08:19 PM
stxchck13
17
02-25-2016 09:59 AM
aerovan
Aerostar
13
11-14-2008 11:26 AM
222mjh
05-25-2007 08:51 AM
Random
Bronco II
07-08-2003 06:37 PM
Quick Reply: Grinding metal sound while turning key
