battery gauage and light
every so often the battery light will come on and gauge will go down low, but still in normal range...then it will pop back up normal and battery light will go off. it comes and goes, doesn't happen all the time. what could be the cause?
truck has a new battery. its a 97 ford f250 heavy duty, 5.8L 5 speed 4x4..257 thousand miles. Thanks!
i took it to napa a few days ago and had it tested, both battery and alternator test out fine, even under load. sometimes my radio wont play when i turn it on, i have to give the dash a small bumb and it'll kick on.
I also took the battery cable off while truck was running, it didn't die or drop idle or anything.
where's the voltage regulator located at on these trucks?
