87 F250 L6 rough Idle issues (amongst other issues)
My cousin had this truck sitting in his driveway for over a year and I finally convinced him to let me have it.. Well I figured out that the fuel pumps were not turning on when the key was turned and the injectors were not getting power. So i traced the problem to the eec relay. New relay did not work but two wires have power, one has ground, and the other one is intact. So i can jump two of the terminals and the truck starts fine and runs, but it has rough idle. Went through whole ignition system, everything checked out. There is a gurgling noise coming from the tank when i put my ear up to the bottom of it... doesn't sound like a normal sound for that pump. The rough idle is consistent like a miss. I drained most if not all of the old fuel out of the tank. Thanks in advance for any help...
Ok, did you put new wires, cap, rotor, and plugs in it? I hope you went either with dealer wires (~$100) or carquest top line wires (~$75), spent ~$35 on the cap and another $12 on the rotor (preferably motorcraft but the high end napa/car quest stuff is good too) and used ONLY MOTORCRAFT COPPER plugs. If you did you can rule out ignition components.
Did you put any fresh fuel in it at all?
What about HEET or other water remover? It's been sitting for a year or so and there is probably water in the fuel.
I put fresh fuel and seafoam in the tank... i did not replace the fuel filter because it was replaced right when the truck went down.. should i still change it? I know the distributor was replaced before the truck broke down.. i am inquiring about the running condition before it stopped now.. but could it be timing?
burgie11570
06-30-2015 02:14 PM
leonard600
09-02-2010 02:55 PM
lavcheech
07-09-2009 10:51 AM
logdog008
07-30-2006 07:02 AM
