Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-25-2012, 08:34 AM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
Garage is empty, add now
fordf350camper is starting off with a positive reputation.
Wheel question.F350 dually
Do ford do a wheel thats tubeless for the f350 dually 16 inch not a split rim or will i have to cut out my wheel centres and have them welded onto modern wheels.Or is the any other wheel that would fit the ford f350 Thanks.Does anyone have any for sale.
  #2 (permalink)
Old 11-25-2012, 09:04 AM
F250racer's Avatar
F250racer F250racer is online now
F250racer is starting off with a positive reputation.
All of our '57-'60 f350s should have 17.5" non-split rims and should be a 6X7.25 lug pattern. I don't know of any other wheel that uses that pattern. If you wanted a different size rim I think you would have to have them custom made.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #3 (permalink)
Old 11-25-2012, 09:37 AM
Hi my ford f350 1957 has 16 inch wheels and they have the ring on the out side of the wheel that you have to remove to get the tyre off thanks
  #4 (permalink)
Old 11-25-2012, 11:23 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I have 6 of the 17.5" wheels and tires for our F350s. The wheels have surface rust, the tires are like new. PM me if you want them cheap. I have posted a lot here about my conversion front and rear to 8 lug modern ford dually wheels. I think you should be able to find info if you do a search. It involves a later model rear axle and 8 lug dually adapters for the front and some machine work. Cheaper and easier to just buy my wheels..... Edit...... Now I see you are in Robin Hood country. Shipping will be a problem...........
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 11-26-2012, 06:16 PM
GB SISSON's Avatar
PM'd you back with weights and measures. Yikes!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
