1967 F100 4BT cummins daily driver build
Old 06-08-2015, 08:12 AM
Lug Nut's Avatar
Lug Nut
Lug Nut is offline
Originally Posted by f100today
Not really sure. Pheonix is confident it will be fine. Hind sight; I wish I would have done the dodge auto tranny. If the 700r4 doesn't work out I will upgrade to a 4l80e.
Sorry I'm a bit late to the dance..
Great work. I'm impressed with the amount of fabrication and detail in you front end work. Having an original style power steering set up I envy your rack and pinion.
I did (am still building even though I've been driving it for over a year) 6BT swap in my 69 camper special.
If you are using the ford rear end make sure your that the final drive ratio in the trans along with you rear dif ratio and tire size don't leave your engine spinning too fast to cruse on the highway comfortably. I had to change the gears in my Dana 60 rear to the smallest set made (3.54 iirc) and still used a 33" dia tire to get my ratios where I wanted them. I have an NV4500 5spd in my truck and now at 65mph in 5th my engine is spinning at about 2.2k rpm.
  #242
Old 06-08-2015, 08:26 AM
f100today's Avatar
f100today
f100today is offline
Let see some pics of your swap!
From what the tranny shop told me; I should be around 1800 rpm at 70mph. That is with a 3.25 gear and a 31.5 tall tire.
  #243
Old 06-08-2015, 08:35 AM
Lug Nut's Avatar
Lug Nut
Lug Nut is offline
I just brought the truck back into my shop to start doing the suspension. I plan on starting a thread here for that and I'll include some background pics too.
  #244
Old 06-08-2015, 05:15 PM
f100today's Avatar
f100today
Originally Posted by Randle
X2 on that looks really nice.
Originally Posted by 71Nky
X3 on the looks
Originally Posted by bajafishnut
Looking real nice amigo, better than factory.
Baja
Thanks guys.
  #245
Old 06-09-2015, 08:51 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Wow, the cab and those fenders look nice!
  #246
Old 06-10-2015, 01:19 PM
f100today's Avatar
f100today
Thanks man. I should be getting the doors and other stuff next week. I need to get my butt in gear and get this thing together.
  #247
Old 06-14-2015, 04:50 PM
f100today's Avatar
f100today
Well, finally got the cab finished up and on the chassis. Starting to look like something now.
Nice reflection on the paint
  #248
Old 06-14-2015, 05:27 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Thanks a lot man for making me drool on my keyboard.
  #249
Old 06-14-2015, 06:56 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
I like the way the liner came out on the back of the cab.
  #250
Old 06-15-2015, 05:16 AM
f100today's Avatar
f100today
Thanks for the compliment!
Thank you, It was cheaper than paint and actually acts as a sound deadener which this truck will need.
  #251
Old 06-15-2015, 05:24 AM
f100today's Avatar
f100today
I tried to get some close ups of the cowl area and the "rain gutter" I made to replace the cowl seal. I hope it works.
Also, a close up of where the cab seam used to be. Filled and smoothed with Valvoline seam sealer two part epoxy and ZERO welding. It came out great.
  #252
Old 06-15-2015, 09:22 AM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
You must be smiling a lot amigo. Your build is way up on the perfect scale, and as close to perfection as a mortal man can expect. Friends are just back from Cuba, and showed us photos of 'Factory Perfect' cars & pickups from the 50's & 60's. Your work would make some of them envious.
Keep smilin'
Baja
  #253
Old 06-16-2015, 11:58 PM
highntight's Avatar
highntight
highntight is offline
Keep smilin'
Baja
X2 with BAja,,, couldn't have said it better, The amount of dedication, time, and skill on this build is beyond me, Should be a sticky without a doubt...
  #254
Old 07-04-2015, 10:13 AM
B.Petry's Avatar
B.Petry
B.Petry is offline
Great build thread! Very nice craftsmanship.
  #255
Old 07-04-2015, 11:05 PM
rustED_'s Avatar
rustED_
rustED_ is offline
^^^X2...Awesome build, very inspiring! I love white on these trucks, makes them look so classy and the body lines so crisp and clean, of course your talent with body work had alot to do with the clean body lines as well!
I just went back through trying to find some info on the wheels you have, sorry if I missed it, but if you don't mind can you post the size again and where you got them...thanks!
Quick Reply: 1967 F100 4BT cummins daily driver build
