How many 97-'03 F-150's came with something like a 4.10 rear end?
Would it even be worth my time looking for such a 8.8 axle with the gearing I want instead of buying the gears and then paying to have them installed?
I don't use my truck as much anymore, but just today it hit me again that I can easily hit 25 MPH in first gear in the damned thing... and that means way too much loading on the clutch for starts on hills, or loaded starts... and the whole truck is geared way too high anyway since the little 4.6 has troubles with the OD gear at reasonable speeds.
I wouldn't mind if first went up to even only 10 MPH. I know it's no creeper gear, but the way it sits is ridiculous.
At the top of this page under articles and specs, beginning in 02, they list all the ratios available over all the build options.
3.08, 3.31, 3.55, 3.73, and 4.10.
To begin looking, you need to list the 'codes' per ratio that appear on the door jamb tag for AX code.
Good luck.
Good luck.
With an automatic trans, the torque converter can still help out on hills at speed. The PCM unlocks the torque converter clutch to get TC action first, and if the engine speeding up and TC action isn't enough, then it will downshift the trans to the next lower gear. With a manual trans, a manual downshift by the driver is the only possibility.
At least for 1997, the standard axle ratio was 3.08, the 3.55 was optional, and the 3.55 was standard as part of the trailer tow package.
When the new truck came out in early 1996, the 4.6L owners who were not happy with performance were by and large those with the 3.08 rear end. That became the first question to ask if someone had a 4.6L and complained about it on hills... "What's your axle ratio?"
