Who's go the biggest
#31
I figured I'd wait for a response, before I explained it technically. It is actually, a 426 C.I.D. Detroit Diesel. It's common name is a 6-71. It has 4 valves per cylinder, and a block mounted blower (since it's 2-stroke, it needs the blower to feed atmospheric air to the cylinders).
They didn't have much of an exhaust system in the planes. Take a look at pictures of a P51 or Spitfire, just ~ 6" long shorty straight pipes to get exhaust outside the cowl.
_
_
I'll also add that the main advantage of the Merlin was the 2-stage supercharger. it could literally be manually shifted into "high" gear to increase boost for high altitude performance. The exhaust driven turbo-charger essentially replaced the (MUCH less reliable) gear driven supercharger. (except in DDA engines!) I must also say that I don't think there ever was a production turbocharged Merlin. OTOH, The P38 Lockheed lightning) had turbo (super) charged Allison V-1710 engines.
#32
The previous mine I worked at had a fleet of 793 Cat OB trucks with 4200cid twin turboed V16s.
scottddove
06-12-2007 09:52 PM
Hiflyer746
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
09-05-2005 02:10 PM
Amule
09-18-2001 07:49 AM
