Poor Idle
Poor Idle
I have a 95 explorer with an idle problem. When I come to a stop, the idle falls very low. If I give the gas pedel a tap, the idle will come up, and remain up until I come back to a stop. This starts after the engine has warmed up, and happens most, but not all the time. The idle, when in park, rises and falls slightly.
Thanks!
Thanks!
Poor Idle
Thanks CobraXP!
I had to have the fuel pump replaced about two years ago. At that time the filter was replaced, and the fuel system flushed. Following a differant thread I tried cleaning the IAC, making the idle problem worse (hence my latest post) and cleaned the MAF. Following the test procedures in my shop manual, I tested the voltage to the IAC with the key on, which was good, and then checked the risistance across the IAC prongs. The manual states 5ohms, I read none, so I think I have a short across the solenoid??
Poor Idle
Bob- I read 10 ohms today with a digital meter. So it appears not to be a short. To me, all arrows point to the IAC, but when it comes to sensors and other engine management, I am far from knowlageable. Could cleaning the MAF added to my problems? Thanks for all the input!
Poor Idle
When I cleaned the MAF, I shot some gum-out at the filiments without removeing it from the surounding assembly, for fear of damage. I have tested the TPS, and according to the vague troubleshooting guidlines in my repair book, it checks out ok. I've never scanned codes before. When scanning codes, will the code resulting from my idle problem be stored, or do the code need to be read while the problem is occuring (while it is idling poorly)? Could cleaning the IAC have dammaged it? My idle problems have become much worse after cleaning it (it was pretty dirty).
Thanks again Bob.
Thanks again Bob.
brooksbronco17
33
05-04-2013 09:59 AM
stangbanger
11-25-2008 12:37 AM
