RPM's drop when stopping or letting off the throttle: New Symptom
When I come to a stop sign or rev the engine, when the RPM's fall they fall really low then mosttimes they pick back up and it idles ok. Once in a while it will fall low enough it will die and need to restart it. Seems to do it once it warms up alittle. It also sometimes seems to have a rough running at idle sometimes but runs fine down the road. I'm thinking IPR or ICP. Should I unplug the ICP and see if it makes a difference?
Unplugged the ICP sensor and no help. I then measured the alternator output and I was only getting 13.0 volts at idle. i'm going to swap the alternator out with my uncle's and see if it fixes it.
I deleted the fuel bowl and only have the regulator up there with no sensors of any kind on it. Pretty sure these trucks don't have a pressure sensor. They have a water in fuel, filter restriction, fuel heater and that's it on the fuel side.
Maybe your thinkin of the ICP (Injection control pressure) sensor that reads high pressure oil to the injectors. I unplugged it and still had the same problem. I have a spare cps i guess maybe I should throw that in for poops and giggles. Can't hurt=) Then will be an alternator swap and then my spare IPR if that don't fix it.
Still no such thing. The PCM monitors and regulates HP oil pressure, not fuel pressure. Hmm, it is possible that old/weak oil could cause something like this.
Not able to swap alternators but a new symtom occured. I started it a few times and instead of dropping low it started to ROMP hard. Like from 450 rpms to 750 rpms and would smooth out after revving the engine. It did that a couple of times today. I've searched alittle and seems that the gear selector switch can cause romping. Could this be my issue? Any other thoughts?
someone else's video but exactly what it was doing. After he revs it you can see rpms drop down to 500 rpms and come back up to normal idle. That's what mine is doing, but a little more severe.
http://s203.photobucket.com/user/agw...d359a.mp4.html
Finally got AE on it and ran a cylinder contribution test on it and kept getting a P0272 cylinder 4 balance/contribution fault. Pulled all the valve cover connectors and this is what the pass nearest firewall looked like.
Gasket looks worse but the under valve cover harness is fine. This is the second time this side has had problems. I put in new glowplugs 2 years ago but i'll ohm them in a little. I'm thinking of putting SD valve cover gaskets on cause of the bigger wire for the glowplugs. Any Opinions?
