Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 11-12-2012, 08:20 AM
blackout150's Avatar
blackout150 blackout150 is offline
2001 Ford F-150
blackout150 is starting off with a positive reputation.
07 Edge Trans issue
Have a really odd problem with my wife's Edge, while driving sometimes the wrench light will come on and it will not up or downshift. If you come to a stop, you can almost not get it moving again. I determined that it is getting stuck in 4th gear. You can put it in reverse and it will not move at all. the only fix is to shut it off, wait a few seconds then restart. It makes a nice loud bang, the wrench light is off and it operates normally. The dealer told me without the light on, they can not pull any codes, it would have to be brought in once it happens. Well good luck with that, it would do much damage to continue driving it that way. It had happened about 3 or 4 times in the time we owned it until last week, it happened once on tuesday and twice yesterday. I see a TSB that reads "DTC P0771, P0774 and/or starts in 4th gear from a stop, harsh 4-1 downshift on drive away at 3mph. 6F50 transaxle built prior to 01-10-007. KB*" This is very similar but mine will not shift until restarted. I am going to talk to the service dept today to see if there was ever a fix for this and see what we can do. Has anybody else seen/heard of this?
__________________
2007 Edge SEL, Copper w/vista roof, FWD
2001 F150 XLT FLareside Ext Cab Oxford White 5.4 Auto 3.55L.S.
1971 Mustang Mach1 M-code, currently 302/AOD, restoration in process
  #2 (permalink)
Old 11-14-2012, 10:04 AM
jk080's Avatar
jk080 jk080 is offline
Gear Head
2005 Ford F-Super Duty
jk080 has a good reputation on FTE.jk080 has a good reputation on FTE.jk080 has a good reputation on FTE.
The real issue here is that the computer has seen a problem related to the transmission, when this happens the computer turns the light on and cuts the power to the transmission. This transmission without power will start off and stay in 4th gear until the key is cycled and the computer resets, then when the computer sees the problem again it starts all over.
The key will be to figure out what the computer sees as a problem, to do this you will need to get the code that the computer has set. This code should be able to be retrieved without the light being on, I am surprised that the dealer told you that they can not do anything without the light being on.
The problem could be a simple fix like a sensor or a switch.
Maybe take it to a transmission shop that you trust.
__________________
05 Superduty FX4
6 inch lift with Toyo Open Country 38s, 5 inch stainless exhaust, SCT tuner, ARP head studs, EGR delete.
Master Certified Transmission Rebuilder of 25 years of all Makes and Models
Transmission Shop Owner and Operator
  #3 (permalink)
Old 11-15-2012, 04:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Garage is empty, add now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The dealer is being stupid. When the wrench light is on a code is stored in memory. It will remain there for about a month after the last time the light was on.
I agree with taking it to an independent shop.
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #4 (permalink)
Old 11-16-2012, 09:25 AM
2001 Ford F-150
Thats what I thought also. I have been doing a lot of research and it seems a lot of people with similar problems are having the TSS and OSS replaced to fix it. I would still like to get the code read to be sure. Doesn't look like too bad of a job to replace them, the worst of it will probably dealing with tranny fluid, I hate the smell of that stuff and it is messy.
__________________
  #5 (permalink)
Old 11-17-2012, 11:44 AM
2001 Ford F-150
Well, no codes stored. I dont know if that is the difference between the engine light coming on and the wrench light coming on, but thats what I got. The wrench light comes on when it happens, goes back off after restart. So now I dont know what to do. I dont feel like throwing parts at it to try to fix it. Really frustrated. I can't force the issue to duplicate, which is what the dealer wanted to do. They wanted to keep it, dont really have the time or pocketbook for that.
__________________
  #6 (permalink)
Old 11-27-2012, 03:02 PM
2001 Ford F-150
Update: Finally it set the engine light on and stored a code, looks like I have to replace the TSS (Turbine shaft sensor). Cant wait, should be great fun from what I have read.
__________________
  #7 (permalink)
Old 12-03-2012, 08:24 AM
2001 Ford F-150
Final update: Changed both the TSS and OSS over the weekend. Found where someone scanned in the directions on how to change the oss from a Ford repair manual, and that made the difference. Was originally only going to change the TSS since that what was throwing the code, but since I had to completely remove the valve body to feed the wire through, I decided I would go ahead and change the OSS as well. $75 for two sensors, $35 for mercon V, and about 4 hours to do the job. The dealer wanted $1000, I think I came out ahead. Fairly simple if you are patient and follow the procedure carefully, lets just hope this takes care of it for good.
__________________
  #8 (permalink)
Old 12-03-2012, 11:24 AM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
Quote:
I hope that fixes it for you. Good on the diy part and saving all the dough.
My 07 has been flawless on the tranny, but had to change a front hub bearing. I've got 85k(wife actually)and she loves it,but I'd just as soon drive my old 99 exploder and I think it's for the better visibility.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
07 Edge SEL+ fwd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
