Heater core
Heater core
3 door heater in my 48 F-68, Canadian built truck. Heater core leaking a bit, so pulled it apart, took off one of the tanks, sure enough full of crud. Will try cleaning cores out, but pretty sure by the time thats done all the buried corrosion under the crud, it will leak a lot more.
Any ideas if anyone makes an aftermarket replacement core, or has a good used core. Alternatively, once I get it cleaned out anyone know of a good "mechanic in a can" product to try and plug up the leaks- heater core only, wont put it in the engine.
- That looks like an aftermarket heater. I would check on eBay as there are several companies/people on there restoring aftermarket heaters of all types. You might check with them or you might see one that you like better than what you have that has already been restored. See http://www.ebay.com/itm/Universal-Heater-Blower-Hot-Rod-Rat-Rod-Ford-Chevy-Plymouth-Hudson-Studebaker-/190753539266?ssPageName=ADME:B:SS:US:1123 and http://www.ebay.com/itm/VINTAGE-ACCESSORY-CATHEDRAL-ART-DECO-HOT-ROD-WATER-HEATER-SCTA-ROADSTER-OG-RAT-/251182489799?ssPageName=ADME:B:SS:US:1123
- Barleak has always worked well. It doesn't crud things up again and it keeps the corrosion under control in the cooling system too.
- You should PM Denny Dahle known as "firstrider" here on FTE as he knows a lot about heaters for these trucks. He helped me find most of the parts for my rare 1950 OE heater.
A rad shop can check the core out and repair it as required. Might be worth a shot.
Brian
If you want to "boil" out the crud in your core I would use Super Clean. Fill you unit 1/2 to 3/4 full then cap off the ports and let it set for a day or so, shake it once in a while and flip it from side to side occasionally.
Drain and flush with hot water and repeat again.
Super Clean works well for heavy cleaning operations but its tough on your skin and the fumes make me gag, but it does work great.
Those are not aftermarket heaters. Those were the standard heater for the 48-50 trucks. That is the heater you got if you wanted a heater but didnt want to pay for the fresh air set up. The actual core has the same dimensions as the 41-48 car and has the same exact motor as the car. it is a reversible motor that has 4 wires coming out of it. All of those heaters also had a drain plug in the core. The trucks used almost the same switch as the car but instead of saying "indirect/direct" it said "defrost/heat" and the brackets look the same but the trucks switch and defroster cable are backwards from the car..
I was wondering about that. I ran my 6 volt heater motor on the bench with 12 volts and it seemed to run real good for quite a while and didn't heat up, or is it doomed?
