Drive Shaft Removal Problem
Old 11-09-2012, 07:34 PM
Morg89's Avatar
Morg89
Morg89 is offline
I have a 1995 F-150, 4.9L, regular cab, 2wd. I need to replace u joints but the drive shaft is held on by some wierd type of bolt and I can't figure out what socket to use. It seems a 13mm, 12 point socket is the best fit...but not perfect. The head on the bolt has many points like a star head or something. Is this stock or did the owner before me just throw in some funky bolts he had laying around? Thanks for any help and I can post pics if needed.
Old 11-09-2012, 07:45 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
No that is stock...... It takes a 12mm 12 point socket..
Old 11-09-2012, 07:54 PM
Morg89's Avatar
Morg89
Morg89 is offline
Well, somebody replaced mine with a 13mm head bolt; tried a twelve but will not fit. I'll go ahead with the 13mm after some PB oil and see what happens. It is just a weird looking bolt head...
Old 11-10-2012, 12:11 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Not 12 point socket like you're thinking of. Its a socket that matches that bolt head exactly, and is called a 12 point, and it is indeed a 12mm. Go to a good parts store and ask for one. If they grab a normal 12 point go to a different parts store. The bolt you're talking about is stock. It is not 13mm. It is 12mm.
Like this: http://www.sears.com/grey-pneumatic-...3&blockType=G3
Not that you need a swivel impact socket. I have a 3/8 drive, non-swivel, non-impact, shallow well socket for the drive shaft bolts.
Old 11-10-2012, 12:33 AM
hunterstroble's Avatar
hunterstroble
hunterstroble is offline
Just use a open end 12 pt 12mm wrench. It's a tight fit, clean rust, mud, ect off.
Old 11-10-2012, 12:37 AM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
Post is dead, move on.
answered to death it has
Old 11-10-2012, 07:16 AM
Morg89's Avatar
Morg89
Morg89 is offline
Thanks for the replies. I get to buy another tool!!!
Old 11-10-2012, 08:52 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Can you elaborate on this? What would be abnormal about a 12 point socket?
I used standard combination wrenches on the companion flange bolts on my dad's truck when we replaced u-joints. I didn't have to buy any special tools.
A 1/2" would be between a 12mm and 13mm in size, so if you can't get a 12mm to fit and the 13mm is too loose, you can try a 1/2 (12.7mm).
Old 11-10-2012, 09:38 AM
jroehl's Avatar
jroehl
jroehl is offline
Clean it first (wire brush, etc.). I've found that if a socket doesn't quite fit, sometimes it's because the head of the bolt (or the nut) is slightly deformed. Tap the socket on with a hammer.
Jason
Old 11-10-2012, 10:50 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
There is nothing special about Ford drive shaft bolts that makes them any different then any other 12 point bolt. Normal 12 point sockets and wrenches fit perfectly.
Old 11-10-2012, 11:02 AM
GoinBoarding
Oh I stand corrected. I have a funny looking socket for those bolts. Guess I should have tried what I had already before buying something I didn't need.
Old 11-10-2012, 11:07 AM
Lead Head's Avatar
Lead Head
There may be special tools with thinner walls or some other change that make the job easier, but normal 12 points work just fine.
BlueOvalBud
28
11-20-2020 09:31 AM
MikeMcCasland
1999 to 2016 Super Duty
12-17-2009 02:53 PM
Ford Breakdown
1983 - 2012 Ranger & B-Series
21
07-18-2008 10:24 PM
mahanson
01-20-2008 04:42 PM
arnold
2004 - 2008 F150
11-11-2007 10:46 PM
Quick Reply: Drive Shaft Removal Problem
