Belt squeak
Belt squeak
ok so i have a 1998 ranger 4.0 and about a year after getting it the belt started to squeak so far if have replaced the belt, replaced the tensioner, and cleaned and wire brushed all the pulleys to remove glazing. and it still sqeaks and its annoying and kinda embarassing have anyone else had this problem if so what did you do
you could try spraying some wd40 behind the pulley on to the shaft and see of the sound goes away.
you could also run the engine (when cold) for a few seconds without the belt on to eliminate some other stuff.
SC_Dave
12-08-2012 08:28 AM
mfp4073
1983 - 2012 Ranger & B-Series
08-23-2008 07:12 AM
