F250 smoke bomb?!?!
F250 smoke bomb?!?!
I just picked up a '73 f250 390/at.
I noticed a giant white smoke cloud coming from it when I came to a stop. Take off and its fine, sitting also. I came down a hill and when I hit the brakes at the bottom it billowed smoke again. And not just a little smoke. Like James Bond smoke screen! I can't see cars through that smoke.
Any ideas what might do that? Seems to be when I brake hard or come to a stop at the bottom of a hill or something.
Double check your trans modulator isnt ruptured and sucking ATF through the vacuum line. Not sure if brake fluid would cause that much smoke, but since you said its when you brake hard- pop the top off the master cylinder and check the level. Pull the vac hose off the brake booster and inspect for fluid. You could have a master cylinder leaking at the back, and its sucking the brake fluid through the booster.
78f3504x4
04-30-2005 05:21 PM
