92 f250 351 Windsor misfires
Hi everyone. I have a 1992 f250 with a 351 Windsor and it has an intermittent misfire. Let me start off and say the truck will run fine then act like it drops 3 cylinders. I just did head gaskets so I have replaced a lot of items. They are plugs, wires, cap, rotor, ignition control module, of course all other gaskets related to the heads being removed. I first thought it was a fuel problem because it would run strong then misfire so I dropped the rear tank and all was fine. Checked the fuel pressure and it was within limits.It will misfire on the front or rear tank. So I replaced the fuel filter. Still same problem. I've checked spark, and compression all good. It doesn't matter weather it's hot or cold. Been running for 5 minuets or 2 days. Also when this happens it starts to smoke real bad and smells like fuel. Once it runs fine there is no smoke. I have made sure the plug wires were put back in the same place to prevent crossfire. I've also tried the old plug wires and still have the same problem. There is no fuel smell from the vacuum line on the pressure regulator and the fuel pressure is good when its misfiring. Any help would be appreciated? Thanks Alan.
O2 sensors are good and all the ignition components are connected properly and in place. I'll have to check the egr. I herd it cycling but it might be cycling at the wrong time. But this misfires so bad it almost doesn't want to stay running. I don't think the egr would make it misfire that bad.
Have you checked for codes? You can have a stored code or other condition without triggering a Check Engine Light (CEL).
Ok checked the egr and it was working. I even manually activated it and it was not the problem I was experiencing. It had a rough idle but it would even out when I gave it gas. The problem I have is it is like it dropped 4 cylinders and it doesn't matter if you are on the gas. I did the test to get the codes and they were 173 hego shows system always rich, 327 evp or dpfe circuit below minimum voltage, 328 egr closed voltage higher than expected, 334 egr closed voltage higher than expected, and 634 mop sensor voltage out of self test range a/c on.
on
All those EGR codes means you probably have an erg position sensor(EVP) fault.
kevman110
07-26-2011 06:06 AM
Mitster
06-03-2009 12:42 PM
