need help with 1997 F250/%.8l efi engine
Old 10-31-2012, 05:21 PM
JWGJR_H's Avatar
JWGJR_H
JWGJR_H is offline
1997 F250 problems
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->I have an F250 titled 1997, suspect was built in 1996. It has the 5.8l EFI engine.
Recently rats chewed up injector connector wiring of #3 & 4 injectors. The wiring was shorted out on these two injectors. The engine would run, but only on 4 cylinders.
I have since replaced the connector wiring. The engine still runs the same as it did, (4 cylinders only), before replacing the wiring. No improvement at all.
I have re laced the plugs, plug wiring, distributor cap and rotor and the ignition control module without success.
Help would be greatly appreciate.
Thank you, Jerry
Old 10-31-2012, 05:26 PM
bashby's Avatar
bashby
bashby is offline
Probably burnt the computer up, injector drivers more specifically.
Old 10-31-2012, 05:51 PM
JWGJR_H's Avatar
JWGJR_H
JWGJR_H is offline
Thanks, Bashby Is there some way that I can test the computer before replacing it? I do not have a code reader or access to one,
Old 10-31-2012, 06:21 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
Assuming your truck is using Speed Density (Batch Fire) engine control you can reference this diagram:
courtesy of oldfuelinjection.com
The PCM fires injectors 1,4,5&8 then 2,3,6&7. All of the injectors should have +12VDC on the supply (Red) side with the key in the On position. The PCM then grounds via the Tan or White wire to turn the respective injectors on.
If 3 and 4 are still not firing it is not a problem with the PCM, it's the wiring or connectors.
Old 11-01-2012, 07:07 AM
JWGJR_H's Avatar
JWGJR_H
JWGJR_H is offline
Thanks rla2005
HooksToy
1978 - 1996 Big Bronco
10-23-2015 07:22 PM
SpringerPop
11-20-2013 08:07 PM
mike L
General Automotive Discussion
15
01-29-2013 06:37 AM
Homelessduck
1983 - 2012 Ranger & B-Series
06-16-2008 05:30 PM
roadrage
06-30-2005 09:57 AM
Quick Reply: need help with 1997 F250/%.8l efi engine
