I got rims out of a junk jard. for my 95 eventhough they are two different sizes can i use them on a 4x4. one set are 15x8 the other set are 15x10 if i use 31s on all four just different widths will it mess up my. four wheel drive if i put the wider ones on the back??
As long as they have the same diameter you're fine. I would also be sure to use the same kind of tire on all 4 rims. Don't mix brands and different tires because even though they say 31", they may be a little off which could potentially cause problems
Thanks i asked alot of people and got a lot of mixed answers like the different widths will mess with the gearing and break while i am turning in four wheel drive
