Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 10-30-2012, 11:31 AM
Asillymick Asillymick is offline
Garage is empty, add now
Asillymick is starting off with a positive reputation.
A few questions on a motor swap
I have a 57 F100 that the 272 gave up on me. I have access to a 95 F150 that has everything there but it is a 5 spd 4X4. The price is right to buy it but I am uncertain of the process needed to convert the 4X4 to 2X4 for my 57. Anyone have any knowledge of what it would take? I would like to keep it a standard just out of nostalgia and I am not finding any other local deals on a motor and tranny combo. My 57 is no show queen it is a truck that is used as a truck should be, and that is why I am leaning toward the F150 because I know it was a towing truck prior to the frame getting bent.
If I left out details or did not mention something let me know. Oh and I will convert it over to Carb because I don't want to jack with the EFI and wiring. Just a pain in the tail.
  #2 (permalink)
Old 10-30-2012, 04:35 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Welcome to FTE!
Why not rebuild the 272?
  #3 (permalink)
Old 10-30-2012, 04:55 PM
Well, the motor needs to be gone through and with winter coming on fast I would like a quick swap. But after posting this I came a across a freshly built 292 so I am trying to work a deal on that. I really would like to keep a Y in it but this SBF is right across the street taunting me. And it is a 5 spd, which I like. Who knows, I have been told just run it without a transfer case connected, but if this 292 pan out then I might be ok.
  #4 (permalink)
Old 10-30-2012, 05:20 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
If your looking to get back on the road quick with a dependable DD, I say go for the 292.
Thats just my opinion and it should be yours. LOL But feel free to use your own judgment!
Good luck in your quest.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #5 (permalink)
Old 10-31-2012, 10:33 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Installing an engine that isn't stock replacement can be a tremendous amount of work. Mounts, crossmember, fuel connections, wiring , exhaust..........It can be well worth it and a lot of fun if you are looking for something specific in your build, but just to get the old girl back on the road, I'd go with the tried and true 292 for sure. my .02
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #6 (permalink)
Old 10-31-2012, 10:42 AM
Well as of about an hour ago I'm up a creek, that motor is gone. And I'm not finding a motor shop locally that will rebuild my 272 heads.
  #7 (permalink)
Old 10-31-2012, 10:58 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
On the 95, the transfer case is bolted to the transmission. Just unbolting it would not work. You would need a transmission that has the end (extension ) housing.
The engine and trans from the 95 are mounted completely differently than the 272, so you would have to make or buy adaptors to mount it in your truck. Then you have the issue of needing a speedometer gear - the 95 transmission does not have that.
All is doable, but can take time and effort.
  #8 (permalink)
Old 10-31-2012, 08:59 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by spurredon View Post
Welcome to FTE!
I don't know about the Op reasons but I hardly ever rebuild an engine. The reason is, I can find real good running used engines for about 10-15% of what it costs to have one rebuilt right, even doing the assembly myself.
On the 95, I would look to trade the 4x4 transmission/transfer case for a 2wd transmission.
  #9 (permalink)
Old 10-31-2012, 09:06 PM
GB SISSON's Avatar
What HE said... A lot of guys are going the other way these days, you know, 4wd. Your 4wd stuff should be marketable.
__________________
  #10 (permalink)
Old 10-31-2012, 09:22 PM
I don't have the 4x4 I just have a 57 with a 272 yblock. I might have found a local builder who is up for the head job and he is very reasonable. It just the past few below 30 temps that are starting to make me freak a little. That temp is cold on a Triumph at 7 am
  #11 (permalink)
Old 11-02-2012, 03:27 AM
Sounds like you need a work beater so you can get the stuff done to the 57.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
