Airaid 400-131-1 System or S&B 75-5032 System or Airaid 860-241 Drop in
Prices I found.
S&B is $269 everywhere.
Airaid is $242 at the lowest price.
Airaid Drop in filter is $53 at the lowest price.
Im really looking for the differences in the 2 brand air filters.
The airaid intake system looks like it can flow more than the S&B system since it takes air from the front OEM location and the top of the air filter box...
S&B intake system ratings.
Airflow Rating: Flows 38.4% Better than the Stock Intake
Efficiency Rating: 99.17% Efficient @ 612 CFM (ISO Course Dust
Airaid intake system ratings.
Flow's over 1406 cfm
21 HP 44 Torque.
Airiad Drop in filter.
nothing...
This is all the info I can find so far to compair the 2 filter brands.
What air filter do you suggest and reasons????
Thank you
21 HP 44 Torque.
nothing...
Thank you
There are three reasons why cold air intakes are a waste of money on a 6 liter.
1, Nothing will ever out filter the stock setup, a cold air setup will dust you're turbo making you clean it periodically.
2, Nothing will be more maintenance free than the stock setup, most stock filters are replaced way too soon @ 70,000 to 90,000 miles.
3, The stock filter will support 500 HP. How can a cold air intake make more power if the stock one is not restrictive.
Over 90% of 6 liter owners do agree with me, all this information is well documented over many internet sites.
X2 what rhjj said, Stock air filter while expensive to replace does the best job. Usually the aftermarket filters require you to wash, dry then oil them, i do not think the oil is good for the sensors and the collection efficiency of the motorcraft filter is far superior to the aftermarket filters in this respect. On the note of dusting your turbo intake, the problem here is the damage done is permanent due to the fact the dusting erodes material off of the turbine blades widening the clearances in the turbo and reducing turbo effectiveness
southbound35west
11-15-2006 09:49 AM
Beast01
10-02-2004 06:36 PM
