Loud clunk noise from bed?
Do you have overload springs on the rear?
If so, going over a sharp bump the axle will jump higher than usual & the overload springs hit the stops with a 'clank'.
It honestly took me a couple of years to figure this out on my truck , because it was intermittent & everything under the truck was tight & solid.
on
When I bought my 88, I also had a lot of noise from the bed area, and I pretty much fixed by:
1. Tightening the spare wheel carrier (I know you don't have one).
2. Replacing the sway bar bushings - they were all shrunken and allowed the bar to flop around.
3. Replaced the shocks - besides being worn out, their bushings were also shot and the shocks would bang agains the bushings quite loudly.
4. Wrapped the tailgate latch pins with electrical tape so it couldn't rattle around.
I also went around and verified that every nut and bolt was tightened to proper specs.
The last thing I am in the process of is replacing the U-Joints which are pretty bad, but I don't think they make much noise.
