Anyone rebuild hub bearings?
on
Heres another stupid question to throw into it.. since it looks actually quite standard once its apart. How possible is it to get away with just reusing the old race?? I mean I've done that on other stuff plenty, but they didnt look like that. I mean in your photo thats not really the issue, even though it is clearly worn lol.
Dont get me wrong, I'd go the ebay route if I were that desperate but, just for discussions sake. Just kind of curious how much an issue that would be in this particular scenario pictured above. I dunno if that bearing looked like that before or after you took it apart
Here is another company making conversion kits to get away from the unit bearings:
Spyntec Lockout Hub Conversions
If you plan on keeping the truck for a long time it may be worth doing it.
https://www.ford-trucks.com/forums/1...l#post11393754
https://www.ford-trucks.com/forums/7...installed.html
coarse threads vs. fine threads
the difference between fine thread and coarse thread is dependent on whether you have a SRW or a dually. The dually uses coarse threads on the front hubs to bolt the dually adapters to the hub itself, not the wheels. the wheel studs are the same thread on the adapter as the fine threaded hubs on a SRW truck.
More to this...
Sort of reviving an old thread because I am in need of replacing/rebuilding my unit bearings. Good info on here but...
On the photos of the disassembled unit bearing, correct me if I am wrong, but that race sure looks pressed in to me. Maybe it's just the pictures that are deceiving.
Consider this, would the metal used in casting the hub portion be appropriate metal to be machined and be hard enough to act as an appropriate race to the bearing portion?
Again, just following up on this, but are you sure that race is NOT pressed in??
No that was all 4 wheels, caliper brackets, calipers, rotors & pads, i finished at 700. I had 1 pin in every caliper bracket frozen solid with the bracket. Ive since had to warranty the 1 front caliper, I think because it gets too hot from the bad wheel bearing haha.. whichhh is how I ended up back here.
So anyone ever give this a try? And find bearing part numbers etc? Probably going to just drop $100 on a cheap one on rockauto, since I know I'll screw up the first go no matter what even if its doable, haha.
#28
I had someone send me one of the newer 2005 +
unit bearings that I was going to disassemble. But
guess what The nut that I marked with the arrow is
not on the new style ones and I can't find a way to
grab it to unscrew the assembly.
So I guess time for the cut off disk in the grinder to make big
parts into smaller ones.
If I find anything worth sharing I'll post it.
Sean
Sean
#29
