06 fx4 4x4 does not work
I am new to this..I just bought a fx4 I couldn't test out the 4x4 prior.. It will not go into 4wd, the light comes on, the shift motor puts it in, but the wheels will not spin. I jacked it up, while the truck is shut off the fronts lock in as they should, start it, and the vacuum kicks and and unlocks them, so if i spin the tire the axle does not spin. I switch it to 4x4, and the axles still do not spin, as in the vacuum does not release.
Also, with the truck off, key on, i switch to 4x4, the motor locks it in and the wheels spin one forward and reverse like they should.
I am thinking a bad solenoid?
https://www.ford-trucks.com/forums/8...then-some.html
welcome to FTE. this is likely the remedy you need.
also if you notice in the center of the page is a "search" button. this usually helps speed up q&a
bigboytoys08
1999 to 2016 Super Duty
03-03-2010 10:56 PM
