'95 Powerstroke starts, then dies
Old 10-14-2012, 11:45 PM
Powerstroke1995's Avatar
Powerstroke1995
Powerstroke1995 is offline
Just ran into another problem with my '95 F250 Powerstroke. After the truck had sat for a year with me trying to find the problem for it not starting, I replaced the IDM and it fired up, and was running very well. I drove it about 300 miles, then tonight as i was leaving the driveway it died, just as if someone shut the key off like the last the truck had a problem. This time, it fired right back up, then I drove another 20 feet and it died again, this time the Check Engine light came on, and would crank but not start. I let it sit for about 2 minutes, then the check engine light went off, and I tried it again, and it fired right up, ran perfect for 30 seconds, then died again, and the light came on again. Now, when the Check engine light comes on, there is also no wait to start light.
The amount of time in which I have to wait for the CEL to go off for it to start is sporadic. Could be 1 minute, could take 3-4 minutes. The amount of time it runs is also sporadic. Could be 15 seconds, could be up to a minute. One of the times that it was running and died, we heard a bunch of clicking noises (like something electronic switching on and off) coming from the motor somewhere, and this only happened one time. Sometimes, with the key on, the CEL will be on, then flicker off, which will in turn kick the WTS light back on, and then the motor will start and repeat the aforementioned process of running for awhile and dying.
We believe the CPS is good because it was replaced very recently, and the tach moves when cranking. IDM is a rebuilt unit. The PCM was also swapped out with a unit that was completely identical to the original. When the motor runs, it sounds perfect, and the way in which it dies is identical to just shutting off the key. No sputtering, rough idle, etc. Full of oil, Shell Rotella 15w-40. Is a '95 F250 4x4, extended cab, long bed, AT, with 299,200 miles. Any suggestions would be appreciated.
Old 10-15-2012, 01:53 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Do you have a way to scan the codes? Where did you get the cps from?
Old 10-15-2012, 07:14 AM
Powerstroke1995
No, I do not have a scanner. And I believe the CPS is from O'Reilly's. It is a black one.
Old 10-15-2012, 07:48 AM
Red97350's Avatar
Red97350
Red97350 is offline
Try a cps from Ford or International. Sometimes parts stores cps' are bad.
Red
Old 10-19-2012, 08:00 PM
Powerstroke1995
I've been way too busy to try troubleshooting on it, so I loaded it up on the trailer to take it to a Ford Diesel Mechanic we know, hoping it would run long enough to get up on the trailer. Turns out it sat there and ran for a full hour before it finally quit, then after that did the same thing, running for about a minute and then shutting off.
Old 10-19-2012, 08:10 PM
fordman67's Avatar
fordman67
fordman67 is offline
Itz a cps.ill be surprised if not.
Old 10-20-2012, 12:57 AM
Lazy_pig's Avatar
Lazy_pig
Lazy_pig is offline
it must be never heard of anything else doing this X2 on the ford or international parts
Old 10-20-2012, 07:53 PM
lannypyeatt's Avatar
lannypyeatt
lannypyeatt is offline
my truck is doing the same thing and i just changed the cps and it still does the same thing, what else could it be?
Old 10-20-2012, 11:16 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Try changing the glow plug relay.
Old 10-20-2012, 11:19 PM
lannypyeatt
Did that, I kept blowing the #20 fuse any other ideas? I'm stumped
Old 10-20-2012, 11:34 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Is it blowing fuse 20 or 22? Welcome to FTE btw!
Old 10-20-2012, 11:44 PM
lannypyeatt
sorry #22
Old 10-20-2012, 11:47 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Unplug the fuel bowl heater, if it's still plugged up.
Old 10-20-2012, 11:50 PM
lannypyeatt
No its disconnected, it runs fine for a few minutes then starts clanging really load then dies, wait 30 seconds and it starts right back up and does the same process all over
Old 10-21-2012, 12:02 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
Well, I'm not sure, maybe someone else will chime in with some info. There's a great bunch of guys on here who know a lot about these things. Sorry I don't have more to offer.
Quick Reply: '95 Powerstroke starts, then dies
