Trying to determine the year of this F1
It is the 1948-1950 type F1. But lack of column shift makes me believe it is a '48 or '49 as I was told the column shift appeared in 1950. It was found with no engine or transmission, no license plates or title. Just an old truck from a farm.
The frame number is *C431094*.
The tag on the firewall is stamped 98RO*C431094*RIC.
The firewall itself is stamped RHFAT707246.
I hope there is someone here smart enough to help this newbie out.
on
Pic's always help
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
Look at the back of the cab. If it has the three support ribs it is NOT a 48. 48s were smooth. Look at the bugs on the glass there will be two small letters and for example it said "DI" It would be a 49 (count the letters in alphabetical order) You could take the speedometer out and try to find a stamped date. Also if it it has a stock heater on the back it will have the date in yellow ink. If it has a dana 44 then it will be a late 50.
I haven't done anything. The previous owner upgraded a 5.0 and four gear tranny into it. Then primered it and added some rims.
If I knew what a Dana 44 looked like that would be fine.
This post was also made on the Ford Barn. mtflat decoded it as a late 50.
Doc, this truck was for sale on CL in Sacramento, CA. A friend of mine thought about buying it, but never went to check it out. The PO advertised it for something like $7500, but over the phone told my friend that he'll take $6k. From what I remember, it has a newer engine and transmission. I believe that it was also the PO's grandfather's truck.
