clutch fan vs flex fan
Old 10-14-2012, 11:44 AM
RockWVU's Avatar
RockWVU
RockWVU is offline
1986 f350 460.
Just did a rebuild and reinstallng the motor in the truck.
What is your opinions on keeping the clutch fan or going to a flex fan.
If i keep the clutch fan setup, is there a way to "bench test" it to see if it works properly?
This truck has the big radiator, with tranny lines going to it, plus an oil cooler, a/c, etc.
Old 10-14-2012, 08:19 PM
mark a.'s Avatar
mark a.
mark a. is offline
Given the factory clutch fan against the factory flex fan, the flex fan will cool better.
Old 10-14-2012, 08:40 PM
RockWVU's Avatar
RockWVU
RockWVU is offline
Do you know what factory flex fans will fit?
I assumed they were all clutch, and i'd have to go aftermarket for flex.
Old 10-15-2012, 09:50 AM
mark a.'s Avatar
mark a.
mark a. is offline
Mine is off a 351M-400. I had to drill the center of the spacer out to fit the 460's water pump, the bolt holes line up though.
Ritory
11-22-2010 04:02 PM
Nathan Plemons
16
11-13-2010 05:26 PM
berry1234
03-28-2010 09:40 PM
n9lhm
47
07-05-2007 06:59 PM
Supercab
05-02-2002 09:31 PM
Quick Reply: clutch fan vs flex fan
