1987 302 harmonic balancer removal and changing timing chain ... questions
my truck is an automatic, if i leave it in drive will it allow me to pull the harmonic balancer without the crankshaft turning or should i just remove starter and lock up the flywheel?
presently i have the rotor pointing at the number one terminal and have the harmonic balancer set a 10 degrees btdc. i should be in timing. after i remove the balancer, and remove the cover, if the crankshaft has moved how will i get it back in the correct position before i install the new chain and sprockets?
any help you guys can give me would be greatly appreciated. thank you very much.
rbthayer
08-03-2003 08:06 PM
big block power
01-07-2003 10:09 PM
Dave
11-26-1999 07:00 PM
