Coolant in radiator won't stay full.
on
I was having trouble with the 6.8 gas 4wd truck going into limp or failsafe mode after loosing most of the radiator water through the cap so after making some changes it runs fine but won't keep water in the reservoir higher than 3" below the minimum fill line. Here is what I have done;
> Flushed the system and added 4 gallons of undiluted antifreeze.
> New thermostat.
> New cap.
> New bottom hoses.
> Cleaned the radiator and condenser front and powerwashed them.
The viscous drive fan seems to be working fine and spins the fan pretty good until it warms up (normal) and it never gets hot. It just won't stay higher than 3" below the min fill line. (It comes out the top and the tank is not cracked).
> New thermostat.
> New cap.
> New bottom hoses.
Do you have a way to monitor your engine temps? My scanguage II gives me accurate numbers to monitor.
How does the upper rad hose feel? When the truck is up to temp, squeeze the upper rad hose. Can you feel the coolant rush back when you release it? If not, your water pump may have failed.
on
thedopefishlives
07-10-2018 02:08 PM
BeerCan500
09-18-2012 11:22 PM
