1993 ford f150 8ft bed
Been beating myself pretty good with local body shops as to how to restore the bed on the f150. Got the corrosion coming through around the wheel wells. Don't mind spending the money and putting in the time to get it done but, would like to get it right the first time. Any help with premium replacement panels, techniques, etc would be appreciated. Have already determined that removing it and spending some time in the garage is essential, have most of the tools and a neighbor who works in the field. Would not be opposed to a new bed if available. Front Cab is rot free.
1st you need to cut off the old bedsides and inner wheel weld arches by drilling out the 100 or so spot welds.
Take the new wheel well inner arches and put drain holes in them(pics below)
Then PAINT the backside of the bed side and inner wheel well arch.
Use Panel bonding Adhesive to glue the top bed rail, wheel arch and lower rear bed support. Spot weld around the tail light and front leading edge.
After you are done welding PAINT the welds from BOTH sides
OR you can do what I said for under 1000 in material and it will NEVER rust out
Do NOT undercoat. All that does is trap moisture against the panel and rot it out. Paint or use POR15 on the under and backside
Here is a dually bed I am making.
FULLY sandblasted, then POR15, Then tractor black.
The whole truck got the same treatment
I am going to run this truck in every sort of weather, I did it to LAST
I used a heated power washer to strip the zeibart off
79 f-150 guy
35
11-29-2017 10:35 PM
crucialprospect
11-07-2017 11:48 AM
Rocksetter
03-09-2010 09:45 PM
