Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
  #1 (permalink)
Old 10-09-2012, 02:42 PM
Dtmaster2008's Avatar
Dtmaster2008 Dtmaster2008 is offline
1976 Ford F-100
Dtmaster2008 is starting off with a positive reputation.
4bbl manifold for a 390
All is well with the engine, from the looks of it something just caused the timing to jump so now I dont have to worry about an engine swap anymore. I can get a Holley 4bbl but now my only thing is finding a manifold for the engine. Anybody have a 4bbl intake looking to get rid of, its a 390FE.
  #2 (permalink)
Old 10-09-2012, 08:11 PM
ChiefM's Avatar
ChiefM ChiefM is offline
1979 Ford F-100
ChiefM has a very good reputation on FTE.ChiefM has a very good reputation on FTE.ChiefM has a very good reputation on FTE.ChiefM has a very good reputation on FTE.
Glad to hear the engine is OK, What are you going to do about the bent valves?
__________________
Stephen
Georgia Chapter Leader
1979 F100, 351M, C6, long bed
Join the Georgia Forum- Click Here
  #3 (permalink)
Old 10-10-2012, 01:53 AM
1976 Ford F-100
Quote:
since the timing gears got, due to bad gas/water in the fuel, were gonna get a new set of them as well as another lifter as one of the went to bits. I've got a full set of push rods so basically after we replace the timing gears it's back together it goes and since we done took off the intake I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***.
  #4 (permalink)
Old 10-10-2012, 03:21 AM
smokenchoken's Avatar
smokenchoken smokenchoken is offline
1978 Ford F-150
My Garage
smokenchoken is gaining momentum as a positive member of FTE.
Eli Hopkins
I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***. that's funny...... but seriously there might be something more serious if a 2bbl 390 doesn't have that much power (i have run 360's and 390's w/ 2bbl and they were plenty stout) and you said it jumped time i had a 352 jump time and all sorts of bad things happened how did your dizzy gear look when you pulled it out???
__________________
smoke n choken out the neighbors with wonderful tire smoke
  #5 (permalink)
Old 10-10-2012, 05:45 AM
1976 Ford F-100
We havent pulled the gears out yet, thats our goal for today. Hopefully nothing else will go wrong as from the looks the heads are in good shape and from what we looked at the cam everything seemed to be in good condition. Anything that came off the truck my dad would have looked at and would have been able to tell right off as he has a little experience with old dentsides as one he used to have was a 77 f100 with a 302.
  #6 (permalink)
Old 10-15-2012, 09:40 PM
DeepRoots DeepRoots is offline
Garage is empty, add now
DeepRoots is gaining momentum as a positive member of FTE.
DtMaster, I've got a T intake if you are interested.
I've also got a F427 aluminum intake that requires a lil love to be usable.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
  #7 (permalink)
Old 10-16-2012, 05:17 PM
1976 Ford F-100
Ok thanks deeproots, unfortunately I did have to get another engine in the end there would have more money into the one I had so I got another 360 and now in the process looking over the new one and it also has a 2bbl so I will still be needing a 4bbl intake. Send me a pm on the 2 you have and pictures also if you can. I won't be needin it but in a week or two I will once we get it all setup.
Another question, in all of yall's opinion, would I be better off with a holley 650 or quadrajet 600? I got a holley but a guy I know wants it to drop it on his blazers's 350 he just dropped in it. Main reason I'm asking because he seems pretty insistent and he says the quad was setup for a ford but I thought the quadrajet was about the best you could get period for a carburator, just curious on that one.
  #8 (permalink)
Old 10-16-2012, 11:08 PM
I'm at work.... I don't get home for another 2.5 weeks or so.
If you still need one at that time, I'll pm ya at that time.
Ohh and unless you have an open intake, or use a large open spacer a quadrajet wouldn't work. Stick with a holely for ease of hookup.
__________________
-76 F100 390FE
  #9 (permalink)
Old 11-05-2012, 07:38 PM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
IMO if you decide on a 4 bbl manifold get an aluminum one preferably a dual plane. Your back will thank you.
  #10 (permalink)
Old 11-07-2012, 08:19 AM
1978 Ford F-150
My Garage
Eli Hopkins
go single plane dual plane is for rpms and these motors are not made for the rpms they are made for low end torque
__________________
  #11 (permalink)
Old 11-07-2012, 07:21 PM
I believe if you'll do some research you'll see you have it backwards.
  #12 (permalink)
Old 11-07-2012, 09:20 PM
1978 Ford F-150
My Garage
Eli Hopkins
apparently i am indeed wrong on how i wrote that good catch alex fingers outrunning the brain before morning coffee
__________________
  #13 (permalink)
Old 11-08-2012, 07:23 AM
It doesn't matter anyway... Fe's have such a huge variety of intakes to pick from.
With single plane, there is a huge difference between a Victor, Dove TunnelWedge, and a Streetmaster.
either way, for a stock motor, they are all overkill.
__________________
-76 F100 390FE
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
