front oil seal orientaton, aftermarket timing cover
putting my fresh motor together, 1986 460 f350.
I got an aftermarket timing cover as mine was nasty.
I am second guessing my self on the front seal i installed in the cover.
The 460 book i was referencing stated that on aluminum covers, install from rear. It would only go in one way from the rear and looked like it'd work just fine. Put some sealer on it and tapped in with a larger socket. So i installed water pump and oil pan, etc.
The seal in my engine kit and timing cover kit are identical.
Now looking at it, it looks as if it could go in from the front. My Haynes book shows it going in from them front.
I dont know what to do. which is right?
The timing cover had a nice flat flange on the inside for the metal lip to seat against unlike the factory one that has a rounded edge.
Should i finish getting the motor in the truck and see if it leaks? or change it now? what is correct?
Advice?
Advice?
The seal lip should point towards the engine,ie;the oil source. Use the crank spacer to align the cover prior to tightening it.I installed mine from the back with the lip facing the engine.By "lip" I mean the neoprene lip with the spring on the inside.You should be able to see the spring after install.
i just tore it all apart. Apparently, there are two types of seals. I am not sure of the year, but there is an early style and late style for lack of better terms.
the book i was reading was dated late 70s, in the author's defense, i think there was only one style of seal and i was mislead by the info it said.
Mine is the late style. it should have been installed from the front. This also allows it to be changed in the future without removing the whole timing cover.
lots of gasket scrapin, no fun.
feel free to correct me if i am wrong on this.
Then yours looks like the seal on the left.What brand gasket?I have a Felpro and a MrGasket set and both are like the right side.The flanged one is facing up and that side goes to the engine.As long as the seal fits and the lip faces the engine,you shoud be alright.The seal on the left is from a SBF 351W.Only used for the picture.
It was included with my fel-pro engine kit that came from the machine shop that did the work on my motor.
I also got another one just like it from Napa as part of timing set gasket kit. Felpro as well.
I guess it must just go off of the year that you tell them it is.
As i said earlier, the manual i was reading had a copyright of 1979 or so. I assume ford came out with the different type of seal after that.
Ultimately, the other night, i tore everything apart and replaced the seal, and installed it the correct way, spring/lip inside, metal flange outside.
Thanks for your help Van, hopefully someone else can benefit from this.
xjpilot
05-22-2011 08:41 PM
sparky69
12-02-2005 01:33 PM
ranger429
08-03-2003 04:13 PM
