Need to rent, buy, borrow DPF
im buying my first diesel, 08 f450 and it has EGR but missing the DPF. does anybody have one i can buy, borrow, rent so i can get emissions passed? also, thinking out loud here, if the DPF is missing, that means a custom program is running the computer, right? what would be the work around this?
Im in Littlerock, CA
According to this document, the seller is required to furnish you with a valid smog inspection certification:
Smog Information
You can enter the vin or licence plate number through this link to see the results of past tests on the vehicle:
http://www.smogcheck.ca.gov/mobile/S...searchType=LIC
Smog Information
exempt from compliance, but that has changed.
"Bringing in an out of state vehicle or buying a car
from out of state.
If you just moved to California with your out of state
vehicle, or you bought or are planning on buying an
out of state car, in order to register it in California
you will need a California smog check certificate."
Bringing in out of state vehicle into California. What you need to know about buying a car from out of state - SmogTips.com. Moving to California and the smog check. How to register your out of state vehicle in California, smog inspection and insuran
patrick1989
1999 to 2016 Super Duty
30
07-15-2011 01:20 PM
