Difference between ASF-32P and ASF-42P sparkplugs?
Old 09-26-2012, 06:56 PM
Anafiel's Avatar
Anafiel
Anafiel is offline
Someone gave me a set of Motorcraft ASF-42P Platinum plugs for my 92 Bronco. I looked them up and they are the alternative plugs for the 302 engine. I have the 351W engine, which calls for the ASF-32P plugs as an alternative.
What's the difference between the two? Can I use the 42P plugs in my 351?
Thanks!
Old 09-26-2012, 07:41 PM
86fn150's Avatar
86fn150
86fn150 is offline
different heat ranges.one colder(32 vs 42).take them back and get the asf 32 cf4.these are the regular style ones.the platinum aren't worth the money and of no benefit on these trucks
Old 09-26-2012, 07:58 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
There is a 99% change that your 351W has the same old D8OE heads as my 302. I don't see any issues with using them.
Edit: I am probably wrong, I was thinking of your 1985. The 1992 probably has better heads. E7's maybe?
Old 09-26-2012, 08:04 PM
Anafiel's Avatar
Anafiel
Anafiel is offline
Originally Posted by 86fn150
different heat ranges.one colder.take them back and get the asf 32 cf4.these are the regular style ones.the platinum aren't worth the money and of no benefit on these trucks
Yea, but like I said, someone gave them to me. No place to take them back to. I normally use Autolite 25 coppers.
Old 09-26-2012, 08:07 PM
Anafiel's Avatar
Anafiel
Anafiel is offline
So which are the hotter plugs? I normally use one step hotter Autolites...it helps to keep them from fouling in my nearly 300k engine.
Old 09-26-2012, 09:30 PM
86fn150's Avatar
86fn150
86fn150 is offline
the 42 are only one step hotter.ford calls for the 32 in 4bbl and 42 in 2bbl
http://www.dj-sures.com/GraphicFiles...ringSystem.pdf
Old 09-27-2012, 06:37 AM
Anafiel's Avatar
Anafiel
Anafiel is offline
Perfect! Thanks for the graphic.
Old 09-27-2012, 07:30 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Yes, thanks for that graphic. Reps to you for that.
I'm running ASF32C's in Dad's truck now, although that engine was in Rusty previously. It came to me with ASF42C's and the porcelain was white. Like new. So, I dropped to the 32's and dropped the metering rod size one notch in the E'brock 1406. Still don't have enough miles on it to know if it helped or not. But, I'm also installing the E'brock A/F Ratio Meter so I can get it sorted.
fordinmudd
Modular V10 (6.8l)
03-20-2008 08:45 AM
FixOnRoadDaily
11-06-2005 06:36 PM
Jrock909
11-28-2004 06:32 PM
w76ford
04-01-2003 07:57 PM
JJH
09-14-2002 05:14 PM
Quick Reply: Difference between ASF-32P and ASF-42P sparkplugs?
