where to find a Dana 24 rebuild kit???
It's a leaky mess. I believe it is still the "original" unit from my 67 f250. Just trying to make it mechanically sound.
Update on Dana 24 Transfer Case
Hi guys - the case of totally disassembled on my '67, F250. The two shafts have a little wear bead in them, so looking for the replacements - also this pin in the picture. The the input yoke is a little warped, so wanting one of those as well. We have everything else that came in the Cobra rebuild kit on seals and bearings.
Weld and spin grind will fix the grove around the shaft and the hole. After that the hole will need drilled out for the pin and the slot milled for the yoke. I'm thinking the groove is from the oil seal holding water and rusting because it doesn't spin or carry a load. Several companies sell new shift rails for the 205 so maybe they could help you. JB Custom FAB, Jeff's Bronco Graveyard ect.
oldblue18
11-04-2002 03:13 PM
mtcwby01
10-28-2002 11:32 PM
fordmanSLO
07-19-2001 10:19 PM
