Turn over Flathead by hand
Old 09-15-2012, 03:20 PM
lvs2fly's Avatar
lvs2fly
lvs2fly is offline
I have a '51 Ford F1 that has not been started since 1975...I'm trying to start it just to see if it will start before I rebuild it...I've soaked the cylinders with oil twice...what is the best way to turn it over by hand. It's tore down to the engine and cab, so getting to everything is pretty easy. I did try bumping the starter, but it just spins and won't engage. Any help would be appreciated! It's my first project like this, the truck belonged to my grandfather, he bought it new in 1951 and it's been in the family ever since. Thanks!!
Old 09-15-2012, 03:35 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
Get a socket that fits the crankshaft bolt, use a breaker bar, and try turning it clock wise. If it don't turn, don't force it, remove the heads and check for cracks between the valves and cyl's. It may have stuck valves too.
Old 09-15-2012, 08:30 PM
lvs2fly's Avatar
lvs2fly
lvs2fly is offline
Success!! That worked...can't beleive it turned over...I turned it about 25 times. Thank you!!
moneypit79
18
05-03-2015 04:52 AM
beckman
06-11-2013 11:00 PM
beckman
03-14-2013 11:35 PM
maestro1024
30
01-29-2013 05:06 AM
bronco
1978 - 1996 Big Bronco
09-11-2000 02:59 AM
Quick Reply: Turn over Flathead by hand
