having trouble disconnecting tranmssion cooler line from radiator
Any suggestion? I have the special tool but unable to push in and release the lines. they are a little rusty. Got to love new england. I unsrewed the fitting from the radiator so that I could remove. The new radiator has new quick connect fittings and I would like to use the new ones. help!!!!
After you install the new ones you may want to cover then with
some thing like cosmoline >>>Cosmoline - Wikipedia, the free encyclopedia
Sean
Sean
Thanks guys for the info
Thanks for the suggestions on quick connector release, none of the suggested additives work as well as I would have liked,even warmed them up a little to get the oil in. I was able to loosen the quick connectors from the radiator and reuse the the old fitting and lines on the new radiator.
The trucks been down for over three weeks now, the first new radiator arrived damage by FED-EX top tank broken, so finialy the second replacement arrived yesterday, Wow I'm ready to roll. Inspected the replacement and all looks good so we carefully install this nice brand new shiney radiator, also did the blue spring thing while we were in there.
So now we have all buttoned up, let"s add some coolant, after the first gallon let's check for leaks. Holly $$!@#$ she's dripping near the drain valve, aha maybe we did not tight the valve, nope thats ok. Took a closer look and its leaking between the tank and core where they are crimped together. If it were not for bad luck I'd have no luck at all. Guess we will do it again tomorrow, I'v had enough today, It must 5 o'clock now!!!
bellinoracing
2004 - 2008 F150
52
09-10-2019 11:26 PM
Bobseaweed
1983 - 2012 Ranger & B-Series
08-13-2007 08:35 AM
Quick_Rod
12-06-2004 06:09 PM
