Rusty Armadillo :: A Restoration Story
#62
#63
the VIN is 97HC 234907 DAL
So,I'm assuming the 9 = 1949, and DAL means it was manufactured in the Dallas plant...
Can someone post up a decoder diagram that clearly calls out the rest of the VIN?
The decoder here on the site says it's a F1, 1/2 ton, 6 cylinder engine, which is consistent with what I found when initially looking up the VIN.
But now I can't seem to find the chart I was referencing originally...
The change in the bed sides happened in mid 1950. The data base Texan2004 has lists the following two trucks assembled in Dallas:
97HC217436 1949 Raised Panel Bed
98RC261916 1949 Raised Panel Bed
Your truck falls between these two so it's reasonable to assume that the original bed had raised panels and that it's been replaced like dmack91 said.
My truck, VIN 97HC312907, was assembled in Dallas in August 1950 based on the code on the firewall - DAH837. It does not have the raised panels on the bed sides.
#64
Ct50f1, thanks for that run down. it's much easier to get focused info rather than drudging through that giant thread about vin numbers. I thought there was a diagram or spreadsheet that broke down the codes... Where can I find that?
Also, any idea where the vin numbers are on the frame? I took a peek yesterday, but didn't locate them...
#65
#66
The number is stamped on the top of the left (passenger) side frame rail near where the engine mount attaches.
You may also be able to find the assembly information on the firewall just above the seam
#68
ha, thanks guys. I found the VIN on the frame, exactly where you said. It was hard to locate due to a thick layer of surface rust, but nothing a cleaning pad and some break fluid couldn't knock out.
It matches the VIN on the tag, so that's a step in the right direction. (I'll take a peak above the seam next)
Are the rear fenders the same for 49-52?
#70
The rear fenders for '48 to mid '50 are notched to the conform to the raised panel on the bed side. Later fenders are flat all along the inner surface where they attach to the bed side.
mkassab
133
02-29-2024 12:03 PM
TonyB55
57
12-30-2019 10:03 PM
AZAV8
20
06-21-2019 11:53 AM
irondragon79
07-22-2014 09:28 PM
