1968 f250
Is he talking about Ford not coming out with a shortbed f250? Or in general? Ford had shortbeds..not sure on the f250.. but you could probably look at the vin number to see. It would take quite the amount of work to convert from one to the other. Are you sure its an f250? I'm not trying to play you dumb or anything. But I'm just lookin at all aspects the vin would tell you if it was an f100 or 250
Not strange at all for an F250 Regular Cab to have a short bed if the original purchaser was the US Gov't or it was a Domestic Special Order. Look on the Warranty Plate for the DSO code, post what it is.
Do NOT believe the miles shown on the odometer! The odometer reads to 99,999.9 then returns to ZERO!
You can get much more info, including a copy of the original build sheet, window sticker from martiauto.com as Marti has ALL the original 1967/79 FoMoCo records.
roninx17: 1967/72 Camper Specials use the same 8' Styleside bed as other F100/350's.
EVERYTHING that made up the Camper Special package (with one exception) could be ordered for all non Camper Specials.
68cabby: The VIN has 11 digits. There is no code within the VIN that decodes to a pickup until 1973.
1970/72: Only the 3rd digit of the BODY code stamped on the Warranty Plate decodes to a pickup.
on
This I gotta see. Yes an F250 short bed is rare like the CS longer bed is rare. A standard long bed is shorter than a Cs bed. ND can shed some light on this I think cant'ca Bill?
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
N-O-N-E = NONE!
The only variation: 1973/79 F350's on the 140" wheelbase (1973/76 Super Camper Special, 1973/79 Trailer Special, 1977/79 Camper Special-Ford dropped "Super" after 1976) have the rear axle set back further than other F350's, but the Styleside bed is still 8' long.
on
Tricky, are you sufferin' from cabin fever livin' on that island? What year Camper Special has a different length Styleside bed than a non Camper Special?
N-o-n-e = none! 1973/79 F350's on the 140" wheelbase have the rear axle set back further than other F350's, but the Styleside bed is still 8' long.
Hope ta see you, She who Must be obeyed, And yer pack of 4 legged youngins.
Yer right. Gotta get off this Rock.
With 4,500 miles, I'd be more inclined to believe the truck spent many years on an aircraft carrier than at a shore based Naval Air Station.
How far could one drive on the flight and hanger decks? Depends on the length of the carrier.
And, if on a carrier, this could account for the F250's short bed. The DSO code will tell the tale if purchased by the US Gov't...or not.
jaskoskip
04-25-2018 07:47 AM
fsr88
07-15-2013 09:50 PM
