Transfer case rear output seal
Hey folks, i replaced my 1356's rear output seal yesterday and didn't notice how the seal was oriented when i removed the old one. What i mean is, the new seal has a hole in the rubber. i wasn't sure if it was a vent hole meant to be installed upwards, or a drain hole meant to be installed downwards. I didn't want my new seal to leak so I oriented the hole upwards. If it needs a hole in the bottom, I can heat up a nail and poke a new one if I have to. My handy Chiltons (Sarcasm) manual doesn't address this.
I don't know this T-case but i looked around. I found some pics but i don't know if they would help at all, i don't see any hole.
1994 Ford Bronco drivelines pictures, videos, and sounds | SuperMotors.net
Couple other vague pics, scroll down till you see yours.
Ford Transfer Case Identification
And finally, a sort of.. Archive of places to check. scroll down once more till you see 1356
http://www.broncolinks.com/index.php?index=70
Good luck.
Good luck.
herbiemin
05-28-2015 10:10 PM
muscletruck7379
11-07-2014 07:45 PM
95f150
05-15-2005 08:55 AM
