78, F100 Fuel Line
300 cid fuel line
Thanks Mike.
Is that how they looked and were routed from the factory? They all look kinda rough, as does mine. I am goping to replace it and was wondering what the factory installation looked like. None of the after market suppliers offer the line between the fuel pump and carbureator, now I see why. Do you know if they were copper or stainless?
Larry
Larry
The originals were carbon steel, same material as the steel brake lines. These are fairly easy to fab. Any auto parts store is going to have steel brake lines in stock. IIRC the line from the pump to the carb is 5/16". I usually use a long piece of wire or brazing rod to bend up a pattern, then measure how long it is and add a little. Then get a piece of brake line that length or longer and bend it to match the pattern. The line isn't very expensive so if you make a mistake it's not a big deal.
When I bent the fuel line on my project, I tried a half dozen different patterns untill I had one that I liked. Probably had $25.00 in the whole deal.
gwcrutch
08-30-2023 02:17 PM
farmnaggie
09-23-2014 08:36 PM
