Help!
Old 09-06-2012, 11:48 PM
Smitty52883's Avatar
Smitty52883
Smitty52883 is offline
Help!
Hey all,
I have a efi 7.5l 460 engine with a little over 3000 miles on it, and the tranny blew. I would like to replace it rather than rebuild it. And I would like to have a six speed rather than an automatic, can anybody give some suggestions for a replacement. The motor has alot of torque so I'm gonna need a good tranny to turn the 410 gear front and rear end.
Old 09-07-2012, 01:21 AM
CS79bronco's Avatar
CS79bronco
CS79bronco is offline
I know the ZF 5 speed will work, not sure about the newer 6 speeds. The ZF5 has the bellhousing as part of the casting so you have to get one for a 460. They are not hard to find, salvage yards are less expensive or you can buy rebuilt or new. Do a google search & you should find several sources.
Old 09-07-2012, 12:01 PM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
Smitty, where are you from? I just bought a Sachs brand Flywheel and clutch set that would fit your truck that I would give you a good deal on.
killa08250
13
11-03-2018 05:17 PM
MrCarlsonq
05-24-2016 01:40 PM
73F100custom
01-27-2006 02:45 PM
sloopy7897
05-21-2005 01:07 PM
Quick Reply: Help!
