Need help chosing an amp.
Old 09-03-2012, 02:08 PM
68bluebeast's Avatar
68bluebeast
68bluebeast is offline
I have installed many stereos and speakers in my cars but I have never done an amp install, I will not have a problem with the wiring I just need help picking out a go amp to match my speakers.
I am running four Pioneer TS-D6802R 6x8 2-way speakers connected to a Pioneer AVH-P4300DVD in my 2001 Navigator. I want to get an amp for the speakers so they sound better, but I am not sure what amp to get or how powerful the amp should be. This is the power rating on the speakers:
◦Peak: 520 watts per pair / 260 watts each
◦RMS: 120 watts per pair / 60 watts each
Old 09-04-2012, 07:44 AM
96sherm's Avatar
96sherm
96sherm is offline
I used to do quite a bit of car stereo installs and building...making a list for one more I always matched my amps to the RMS power of the speakers/subwoofers. Only time I would use an amp that was rated more than RMS of the speakers was if I was going to be the only one using the stereo, or if it was a good enough deal to merit taking the chance on blowing something.
Old 09-04-2012, 11:24 AM
68bluebeast
so since the speakers I have are rated at 60 watts each do I need to get an amp that is 60 watts? Or do I get an amp that is 120 watts cause they are 120 watts a pair?
Old 09-04-2012, 07:44 PM
96sherm's Avatar
96sherm
96sherm is offline
a 4 channel amp running 60 per channel, or a two channel running 120/channel. Personally I like to have each speaker on its own channel, so I'd sooner go with the 60/channel x4 over the 120/channel x2. I've done it both ways and can't say for sure that there is much noticable difference in sound when you're only pushing 60w per speaker.
1957F100
11-08-2007 04:02 PM
keja1914
04-08-2006 09:47 PM
xzMonkzzx
05-22-2005 04:21 PM
fordmanforlife
09-08-2004 12:26 AM
Jrock909
06-11-2002 10:40 AM
Quick Reply: Need help chosing an amp.
